LegendRacer wrote:the Rims are 18'' but the stock tires it comes with are a bit wider.
the front wheel is 225/45ZR18 and the rear is 245/45ZR18
having a 245 width, will it fit the coupe? i kno the rims will fit, but i want to know having these tire sizes, will fit or not
also the Bolt pattern is 5X114.3 and front offsets are 27mm and the rears are 23mm. im sure this fits, cause ive seen these wheels on a members coupe before
cheers!
I have the 350z touring rims with offsets of 33mm and 30mm. I have 225/45r18 all around so I have no rubbing issues. What you'l have to do is put the 245's on the front and 225's on the back. This way, you shouldn't have any rubbing issues but will not be able to rotate or drop the altima without possibly having your rear fenders rolled. I would double check as well the offset on those rims, they will be stamped inside the rim itself.
