Will Super Advan wheels clear Z32 calipers?
skydragoness
Car: 03' 350z Touring 6spd
92' 240sx 60k survivor :)
Just checkin' these wheels out. Offset is +32, but I really can't tell from the spoke design if they will clear 26mm Z32 calipers. I figure if they are flat on the backside it may. Figure i'd ask to see if anyone runs these already. Thanks.
yokota180sx
Car: 1997 Stagea RS4, r34 front
it SHOULD
but with that offset, youll want spacers anwyays
skydragoness
If they do clear the calipers, why should I run spacers?
yokota180sx
becuase its a weak *** offset
skydragoness
yokota180sx wrote:becuase its a weak *** offset
Oh that's what I'd thought you'd say
hayai_240
Car: 1989 240sx Coupe
Nope those wheels will not clear z brakes. I have those exact wheels on my s13 w/ the 26mm z32 brakes. You will need a very small spacer to clear. I think maybe like a 5-10mm spacer. Yokota is suggesting to spacers because the wheels wont be very flush w/ that offset.
skydragoness
hayai_240 wrote:Nope those wheels will not clear z brakes. I have those exact wheels on my s13 w/ the 26mm z32 brakes. You will need a very small spacer to clear.
Thanks, that was the answer I was looking for.
KFL
Car: S14
hayai_240 wrote:Nope those wheels will not clear z brakes. I have those exact wheels on my s13 w/ the 26mm z32 brakes. You will need a very small spacer to clear. I think maybe like a 5-10mm spacer. Yokota is suggesting to spacers because the wheels wont be very flush w/ that offset.
I think there are many options for the rim..My buddy has them on his s14 although in a fresh to death 18x9+15 18x10+0 clears zbrakes front/rear.
But with that offset +32 like yokota180sx said spacer..make it sit more flush after the lowering/tire fact.
