will spark plug o ring gaskets from a sentra SE R
RPS13 DRIFTER
Car: S13 Hatch SR'D
fit on a s13 SR20DET?and the valve cover studs on mine are stripped are they the same on a SR20DE in the Sentra SE R's?i was hopping to get them at an auto parts store if they have them for a sentra
Hijacker
Car: '92 240sx Convertible
'94 F-150
Not sure about the spark plug well o-rings. but you can order them from west covina nissan or courtesy nissan pretty easily. Also, the studs are the same as the sentra's (p/n 13508-53J00), except the center one. It's specific to the RWD platform (p/n 13508-52F00), but west covina has them. You'll have to contact their parts team to order it as it's not listed on their website.
RPS13 DRIFTER
Car: S13 Hatch SR'D
ok i only need three studs and the middle one is fine you think i can find the studs at an auto parts store?
Hijacker
'94 F-150
You'll probably only find those studs at Nissan. Also, I hate ordering car specific parts at regular auto parts stores. The OE aftermarket tends to not hold a candle to OEM for longevity and quality.
RPS13 DRIFTER
Car: S13 Hatch SR'D
i dont understand how its getting in the combustion camber if the spark plug well gasket isnt sealing
Hijacker
'94 F-150
If you're getting oil in the combustion chamber, then you have some leaky valve stem seals. The spark plug well gasket would just let it seep into the spark plug well and foul up the tips of the spark plugs.
codyace
Car: S14 w/redtop
Sentra O rings will do the trick just fine :D
