will s15 480cc injectors support this turbo?
wildacexxx
Car: 2002 Q45 nav sport
turbo im looking into has these specs
COMPRESSOR:-Wheel- 56 Trim - 51.6 Inducer / 69.0 Major-Housing- 60 Inlet / 50 Outlet - 0.60 A/RTURBINE:-Wheel- 76 Trim - 53.8 Major / 47.0 Exducer-Housing- GT25Outlet specs:Internal GT25 outlet; 0.86 A/R
i already have 480's and i want to run it at a mild 10 psi till i get enough to get 550's but i want to know if the injectors will be able to hold 10 psi, and if so how much more will they hold? thanx
Blown240sx
Car: 1996 240sx
Suggestion for you if you plan to go more HP later it better just to buy some good size injectors like 740cc or 820cc cause you can always run the injector on a lower load safely instead of pushing some 550cc injectors.
Also You can runt hat turbo on those injecotrs hell you could run 370cc its not the turbo size but the boost you run and the Flow Rate of the turbos in comparison to the psi.
ExampleOld turbo might flow300 cfm or what ever the measurement is
New turbo flow450 cfm
If these are pushed at the same PSI the new turbo will actually push a great volume of air causing a leaner situation.
wildacexxx
theres no point in pushing 740's on this turbo seeing as it will only flow enough for 340 hp. im looking to get 300 hp with 550's but i already have 480's and would like to run them at low boost with the turbo. just want to see if its ok
