will s14 front 5 lug rotors fit s13 calipers?
Drift Augmentation
Hi,I searched and i know that s13 and s14 rear rotors are the same.
Can anybody verify that 95-96 s14se rotors will fit up front?Are 95-96 and 97-98 s14se rotors different size?
Exar-Kun
Car: 2005 350Z
they'll fit with s14 front brakes....
just get Z32 front brakes man, dont waste your time trying to get marginally better(if at all) brakes on the front..if you gho 5 lug, grab q45 or z32 brakes.-chet
Nismo_Freak
Car: 89 Nissan 240SX
97-98 rotors are different size, they are all the ABS type rotors and calipers.
Drift Augmentation
Thanks for the help, but I'm not confident that my rims will clear z32 brakes. That's why i wanted to get s14 front rotors, plus my stock rotors are worn out and i just bought aftermarket s13 pads. If 95-96 s14se rotors don't fit, i would like to upgrade to z32's but i still have to figure out if they fit.
My rim has 1" backspacing, from where the rims mounts to the hub and to where the rimi would hit the calipers.Do you think that 300zx brakes would fit?
If someone has a stock s14se alloy rim, can you measure the backspacing, i'd really appreciate it....i heard that those are pretty much the lowest backspacing you can run.
thanks again for the info
Drift Augmentation
also, i don't have much room for spacers...I got 8" wide with +23 offset and 225/40 series tires.
