Will rotating compressor housing & removing exhaust housing affect balance?
onosqv
Car: '92 240sx Vert
I need to rotate the compressor housing so it points the right direction. I am also removing the exhaust housing to get it thermo-coated & then put it back on.
Will doing either things mess up the turbo balance (i.e. need to rebalance the turbo)?
Or would only messing w/ the wheel/other things make the turbo imbalanced?
THANKS!
fiznat
Car: Grown up :(
Neither should require any special work with the turbo... just make sure you bolt them back up haha.
onosqv
Car: '92 240sx Vert
Thanks, just making sure .
Time to get that super sweet thermo coat goodness, weeeeeeeeeee.
