Will Rota P45R 18x9.5 20 offset fit on front on 97 S14?
Jbravos14
Car: 240sx S14
I want to buy 18x9.5 Front & Rear Gold P45R 20 offset for my S14. But my Q is that if they will fit on the front without rubbing the Strut/Coilover. Do I need anything like Spacers? If you have pictures it would help Thanks
adrianfromthecastle
Car: 1992 Nissan 240sx
You're fine in the rears, but you'll need spacers up front. They wont clear the suspension up front. IIRC, you'll need at the most a +15 for a 9.5" to clear
drifterxdets
will 18 9.5 with +12 offset fit the front cleanly? for the rota p-45r rims
Gabes13
Car: rb20det s13
wait a second.... if 18x9.5 +20 fit on an s13, why wouldn't they fit on an s14?
adrianfromthecastle
pandapants wrote:wait a second.... if 18x9.5 +20 fit on an s13, why wouldn't they fit on an s14?
you know what, let me clarify.
9.5" +20 most likely won't clear coilover suspension up front (generally speaking, depending on what coilovers you have). If you have a spring/shock set up, you'll have a better chance in clearing suspension because the spring sits higher than the wheel instead of beside it...
if you have a 9.5" +20 and it clears your coilovers... let me know.
Gabes13
Car: rb20det s13
I understand that coilover clearance varies between manufacture and what not, but Broadfields running something like 5.50" back space and ?x9.5 +20 is something like 5.53" back space and since s14's are more short and stout than s13's, I just assumed they could swallow bigger wheels with ease.
No??
