Will rims rub?
bfournier
I have a 2006 m35x. I am very very close to buying 20 x 8.5 rims with 40mm offset. All four tires and rims will be identical sizes. Tire size will be 245/35/20. Does anyone think I will have any clearance problems with this combination? If so, would it make sense to get any spacers and what size would give me the best chance of no issues?
Stock is 47mm. 7mm difference between stock rim and new rim equates to about .5 inch. Stock tires are 245s also. so no additional space taken for tire width. Am I correct in saying the only clearance issues I would have is if I dont have an extra .5 inch of clearance (to compensate for the -7mm difference in rim offset) between the stock rim/tire and the fender?
szh
Car: 2018 Tesla Model 3.
bfournier wrote:I have a 2006 m35x. I am very very close to buying 20 x 8.5 rims with 40mm offset. All four tires and rims will be identical sizes. Tire size will be 245/35/20. Does anyone think I will have any clearance problems with this combination? If so, would it make sense to get any spacers and what size would give me the best chance of no issues?
I think you will be okay with 40mm offset, but make sure that the overall tire diameter is similar to the OEM size to avoid fender contact on bumps. I would not suggest using spacers, since that will make the "problem" of fitment worse!
Z
mikeym45x
Car: 2008 M45x
you should be fine, I have a 08 m45x im running 20x8.5 all around with 38mm offset (closer to outside then 40) and im running 255/35-20 no rubs whatsoever, before and after a 1.25 in drop including with 4 people in the car.
