4bangers wrote:thanks for the reply, I have couple questions.why do you need the hydraulic staging brake?Do I need rebuild kit if my caliper already comes with the clips and brackets and stuffs?
I didn't swap hubs for the Cable e-brake. the staging brake is used as a replacement for the cars hand brake system but now as it is hydraulic it is faster requires less effort and I didn't have to spend 3 hours pulling parts off of the Z just to use the back brakes.
You dont need to rebuild the calipers but they could be ranging anywhere from 12 years old to 15 so the boots around the caliper pistons might be bad, its really just all the gaskets. inspect your brakes after you buy them to make sure they wont require a rebuild but honestly the rebuilding isn't hard, you can repaint the calipers themselves while doing so, and its not expensive.so its like this-/+ 12 year old brake calipers < Freshly Rebuilt R32 calipers
