rotorific wrote:Wrong....
Luvs: you did not specify what type of R32 you were talking about so im gonna guess any set except GTR.
180fan hit it right on the money...GTS and GTS-T calipers are exactly the same as 300zx Twin Turbo calipers... aka 30mm 4 pot the exception is that R32 calipers are always aluminum. GT-R calipers are just slightly different. The Bolt holes that mount up are the same but the rotor size is different.
Same goes with R33 calipers...They bolt up and will use the 350z track model rotor.
Lovelesss: I dont know what model you were talking about so.....You cannot just bolt up a 300zx/r32 caliper on a 350z track rotor. Now there is a ebay company that makes an adapter. I honestly am pursuing this setup.
An R32 GT-R will not bolt up to a 350z track rotor whatsoever.
An R33/R34 GT-R will bolt up to a 350zx track model rotor.
Hope I helped out
Sorry gotta add my 2 cents =). So I found the brackets and this is what it says.
240SX Caliper Braket (Pair) Upgrade 350Z Track Rotor with Z32 300ZX 4 Piston CaliperInfo:
Bracket is for 240SX 89-98 S13 / S14 240SX S13 / S14 must use 300ZX Z32 30mm calipers and 350z 12.75" track rotors Simple Upgrade to Bigger Rotor & Better Brake 2 CNC machined caliper brackets Included 4pcs long bolts
So the 350z track editions need 30mm not 32mm. My suggestion go to
http://mynismo.com/products/?id=2897 and buy 32mm rotors instead.
