will Q45 Brake Master cylinder fit to 240sx?
thekawaii
Car: box with 4 wheels
1992 stock q45 brake master cylinder. will it fit to 240sx? bolt on?
jdm_master_X
Car: 92 Nissan 180SX LHD!...LaWL
bump.
neverlift
just got a crazy idea.
Go to the parts store and ask to see both.
Raxephon
Car: '04 RX8...for the moment...
thekawaii wrote:1992 stock q45 brake master cylinder. will it fit to 240sx? bolt on?
It'll bolt up to the booster in my '95, but the plumbing is different.
jdm_master_X
so would that require modified hardlines to the brakes? how about pedal adjustment?
180fan
Car: 89 fastback
You'd probably have to bend around a few of the hardlines. I haven't had the chance to replace a master on a 92 Q so I wouldn't be able to give you a flat out answer either. But I don't see why it would be all that different from some of Nissan's fleet.
