Thanks coaster. For the benefit of others, this
http://maxima.org/forums/autocrossing-r ... t-car.html is the best link I found to the Making it Stick series. I'm not sure if you are making a point about the leverage effects of wider rims, or wider tyres. I'd considered the extra scrub of moving the tyres out, but I think you are slso making a point about the gyroscopic effects of wiht wider rims having more rim mass situated further out, which I hadn't considered.
The stock wheels and tyre combo were 17.5kg and +40 offset. The car had OEM rims on it when I got it so I weighed the unused spare. The GT-R and V35 (not R35 sorry) wheel and tyre combo are both just under 20kg. So a little heavier. Obviously lighter is better than heavier. I understand moving the centre out increases loading on the hub and on steering inputs. That goes to my question about whether the 350Z rims are a good idea, rather than whether they will simply fit.
I'm very happy with the driving characteristics of the V35 wheels. The only reason for swapping them is they do not clear the front calipers without using a spacer. My mistake is I assummed a later model 17x7.5" Skyline rim would clear earlier model skyline brakes that were originally inside 16x6.5" rims. I've never had problems with backward compatability of rims before. The 5mm spacer itself isn't a problem geometry-wise, as it results in the offset with the +45 V35 wheels being OEM, but it prevents the rim engaging on the hub centre, as the hub centric hole does not get close enough to the hub to get past the initial chamfered part of the rim. Engineering work-arounds to fix that all have their issues hence I'm leaning to changing the rims. Next time I will trial-fit first!
My interest in the staggered fitment is because I have always found the car to be tail-happy, even OEM they incline to roll over-steer (I've owned it since 1995) and the front is very trust-worthy, and these days it's 200kw at the wheels, so I run more rubber on the rear than the front, aiming to minimise extra weight and tyre width on the front for the reasons you touch on. It is certainly more pleasant to drive if the front tyre sizes are kept sensible. I'm currently running RE003's, which are not directional (but are asymmetric) so I can still swap them side to side.
