Will OEM studs fit on 20mm spacers?
iXaier
Car: 2006 Infiniti M35
Hey guys, how's life?
I'm about to install 20mm spacers pretty soon, I need to know how long are the studs that fit exactly on 20mm spacers?
OR
should I use OEM studs? will that be okay? no problems???
btw, I have those OEM wheels;
donnieb83
Car: 2007 M45S
Just out of curiosity what company spacers are you planning on running? Anything more than 5mm or 8mm I would run with extended lugs built into the spacers. For 20mm I would recommend Ichiba V2 spacers. You just slide the spacers over your OEM lugs and new extended lugs are pressed into the spacer itself. You can find these on ebay. Below is a pic of what I am talking about.
06M4.5
Car: 2006 M45
in order to run the 20mm spacers you would need to buy new longer studs that are 20mm longer than the stock oem studs.
I agree with Donnie, best spacers above 10mm would be like the pics he just posted.
with any spacers you just need to re-check the lug nuts a few times just to make sure you don't lose a wheel
zerg711
I'd probably buy H&R instead of Chinese made spacers.. You are putting yourself at by using these. You might as well reduce some of it by using higher quality brand
donnieb83
Car: 2007 M45S
^H&R are great spacers also. I've ran both Ichiba V2's and H&R's on my 07 TL-S and 01 IS300. No issues with vibrations on either.
