anyone know if the OEM bearing will work with the RPS clutch setup? I've been told the RPS comes with a "thinner" bearing to work with the thicker pressure plate and that OEM t/o bearing should not be used with the RPS setup, but I've also been told they use the same bearing...
Modified by wayne66 at 8:43 AM 5/24/2007
