Will O2 sensor cause rough idle?
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
tykeeus
Car: 1994 Q45
I have a 94 Q45 with the O2 sensor light on. It has a rough idle. Is that caused by the O2 sensor? I ordered replacements, but want to make sure there is not something else I need to check.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
no it shouldnt. o2 sensors are only used during certain times and they are only used to monitor AF ratios, and can only adjust them by +/- 20% or so...... they have no effect on the idle quality.
tykeeus
Car: 1994 Q45
So what would cause a mold rough idle, but fine at cruise? I checked for codes, but there were none. The car sat for 6 months before I bought it. Possibly plugs and a tune up?
tykeeus
Car: 1994 Q45
That is a MILD rough idle.
T45
Car: King Kong powered Z32
You need to OHM your injectors, run some BG44K through the fuel system, and if you haven't done so already, fill up the fuel tank with fresh 93. Also check the IAC but it's probably an injector.
Return to “VH45DE / VK45DE / VK56DE Forum”
