dntbther »
https://forums.nicoclub.com/dntbther-u190530.html
Sat Sep 10, 2011 7:36 pm
ok everyone i have posted this in other forums but seem to have hit a wall.
the previous owner had a battery that was to tall unnoticed shortly after my purchase it hit the underside of the hood and cause a short. the car still ran but when the key would be turned off it still would keep running. i have changed the battery, the blue fusible like that got fried, the ECU,the alternator, most of the relays(even hidden ones behind the fuse box, ignition switch wiring from back side of the key cylinder. to no avail nothing has changed as far as the car turning off. i even have done the ECU check and code 55 no problems. but i must say it does run much better...lol
if there is anyone who knows the specifics of the ignition. im leaning towards either the starter relay or the wiring coming from the key side of the ignition.. please help i wanna put this behind me so i can start enjoying it and not worrying about it. thanks..
