Truck was running fine, drove down to Houston (~400mi) and drove around town while in Houston. Headed home and stopped for gas ~300mi away from Houston. Got back on the road and about 30mi away from gas station the truck just cut off. It did not choke out or stall trying to run, etc.. it just quit as if I turned off the key. Attempted to restart truck while coasting down the road but nothing. Coasted into small store and when trying to start truck it just turns over - no attempt to fire at all.
Once I got towed home (expensive) I began troubleshooting.
Could not hear fuel pump running when turning the key to the run position, and giving how it died I made the assumption that the fuel pump went out. So I replaced the fuel pump.
Once I could hear the pump, and checked that I had pressure (42psi) it did not change anything as far as starting.
So I began to check all other mechanical aspects.
Have spark to all cylinders.
Have compression to all cylinders.
Distributor rotor turning with no jumping or stopping.
-Still no attempt of motor to fire - just turns over and over.
Once I had run down the battery I decided to disconnect and charge. Slow charge, ~16hrs, full charge and reconnected battery.
Several minutes of priming of fuel system (in the interim fuel line had been opened) the truck started trying to run.
Finally got engine to start, and once it smoothed out I could rev the engine and everything seemed normal.
Let engine run for ~15min while cleaning up tools, and then went out for a test drive.
I could give it gas and lunge forward, felt like normal power.
Got about a mile down the road and stopped at light. When taking off from light it initially accelerated and then began choking out unless I backed off peddle.
Did this for about a minute and then started dying when I gave gas, but could restart and let idle.
I could give it gas as long as I was not in gear (automatic) but died if I tried to move.
Then the engine would no longer start, no attempt to fire and got someone to tow me back to the house.
Now it is just turning over and over not attempting to fire - again.
Thanks in advance for any assistance.
