demonZ73 »
https://forums.nicoclub.com/demonz73-u204047.html
Sun Jul 08, 2012 4:04 pm
i dont know what i did in life to deserve this but i cant get my car to idle after i.......
1. replaced all gaskets and seals
2. bord cylenders .020 over with stock but over sized pistons
3. shaved heads (only enough to clean them up)
4. full stainless sleel exhaust from front to back
5. jim wolf technology stage 3 500 cams from import parts pro
6. egr delete
7.AIG delete
8.throttle body water coolant delete.
9. brand new injectors and connecters (cleaned fuel rail)
10. brand new water temp sensor and connecter
11. brand new fuel temp sensor
12. AAC unit has been completly removed, disassebled, checked and tested cleaned set and put back together and reatached, same with air regulator
13. brand new pcv valves
14. i have 3 groud wires attached to the plenum in the back.
15. did compression test and is good
16. is deff. getting good fuel pressure
17. removed both throttle chambers cleaned very well re-assembled with new gaskets and yes even put both back in sycronization.
18. brand new stock ngk plugs.
19. just got done doing the timing belt and yes this time counted the cogs and still no differant.
20. ohned ignition coils and all getting 1.4 (yes i know it calls for .07 but if the car runs and there all getting that im guessing there good.
21. set TPS at .4 volts i did this with the car NOT running how much of a differance does this make
22. tested my PTU it took me like an hour of studying the manual but finally figured out how to test it, it seems to be ok im getting some readings however all diff. kinds of numbers.
23. ECU code (55) = no errors
i have to hold the throttle a good 1/4 of the way just to keep it idling at about 1000rpms and even then its a little shakey and when i hit the throttle it hesitates bad ......iv been doing some reading does anyine think it might be the mass air flow meter?????...........please help if you can and thank you
