That's what I figured. I don't want to remove fender liner, tuck wires and stuff... I played with my setup Saturday and 2 finger gap worked just fine. When I jack up the car, I can use diff for the back, but for the front, I have to get up on 2x4 to slide floor jack in.nismofly wrote:id say you probably wouldnt want to go much lower, or youd really have to worry about it
btw, negative camber is good, the car comes stock with a bit (-1 ish) and youd probably want to run around that for those wheels, maybe a tad more...
btw, run your coilovers at 0 on the street, then switch to higher settings when you go to the track, itll extend the life of your dampers a LOT
Oh!! I took off the wheels like 10 times and got the perfect height. 2 finger gap(very tight) front and back. Drove around and it seems to be perfect for the road condition where I live. Not too low, not too high just about right. I have exact same wheel gap front and rear. I measured from ground to frame and rear was tad bit higher. That's okay with me. Stance coilover is not bad at all for daily driving... I was VERY impressed.nismofly wrote:so it is or isnt as low as you wanted?
Tight 2 finger gap looks very nice. It was so tempting to go lower, but I had to stop. Yeah, your car will look very nice once you lower it more.nismofly wrote:yeah i was aiming for like 1.5 finger, but i ran out of time so i ended up leaving it at 3, as you can see in my sig
