will my 18x8.5 +39 offset clear my s14?
BlitzMo
im running on z32tt brakes and stock struts...will the 18x8.5 +39 clear?
94_240sx
Car: 94_240SX
BlitzMo wrote:im running on z32tt brakes and stock struts...will the 18x8.5 +39 clear?
That's very close. You might need 5mm spacers to clear struts. I think it will clear z32 30mm calipers.
EazyBreazy
i doubt it will clear the struts, clearing the breaks is more about wheel spoke design than offset. what wheels are you planning on running
94_240sx
Car: 94_240SX
sdwyzs14 wrote:i doubt it will clear the struts, clearing the breaks is more about wheel spoke design than offset. what wheels are you planning on running
s13 7-spoke stock rim can clear 26mm calipers. There are 2 different s13 stockk SE rims. Outside looks same, but inside design is different. Only one of them can clear 26mm calipers. Since width of your wheel is already 8.5, you should have plenty of room for calipers. If not, 5-10mm spacer should take care of it. Spacers will also help clearing struts too.
