H8tred wrote:Most aftermarket wheels have an over sized hub bore. You have to get hub-centric rings.
Yes, you could. But it adds unnecessary weight to the final setup. Although it is small, and it is at the center, so not a bad thing per se. Regardless, why do it?
It still will not be as good as getting correct hub bore rims in the first place.
H8tred wrote:As far as boring them out, Honda guys have been doing it forever with Miata wheels. Not sure what size they're going to though. Nothing a machine shop can't handle for you though.
This is scary, IMHO. You end up removing some significant amount of metal (depending on how much you need to bore it out) right at the place where you need the original design of the wheel to stay as strong as possible. If the machinist is not careful, you could also have balance problems - where the wheel ends up inherently a bit off to begin with, and then you have to add more weight than necessary to balance the tire on the rim.
Plus, if it is an Aluminum wheel, removing the surface anodizing exposes the internal pure Aluminum. This is going to oxidize and pit a bit right where the "boring" was done.
Finally, it adds cost to the end result.
Again, why bother? It is better to just get the correctly fitted wheels in the first place!
Z
