Will m35 stock 19 inch rims fit on a g35 coupe 2004??
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
etschell
Car: 2007 f17
anyone know?
joe603
Car: 2014 Durango R/T
yes, i've seen a pic...do some searching on the net, I'm sure you'll find one.
szh
Car: 2018 Tesla Model 3.
etschell wrote:anyone know?
Probably not without spacers. The offset of the 19" M Sport wheels is very high and does not work for most other Nissan and Infiniti cars. They will contact suspension components.
You would have to use like a 10 or 15mm spacer and this has its own set of issues that make me leery of doing it. See the sticky threads in our M35/45 forum for more info.
So, if you really want to change the wheels on your G (personally, I'd rather spend the money on outstanding tires for your existing wheels, which are 18" as I recall!), then check out after-market wheels on Tire Rack and elsewhere.
Z
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
