Will Lexus GS 350 rims fit a G35 sedan ???
eyekutr
Quick question for you wheel gurus....Will Lexus GS 350 rims fit a 07 G35 sedan ??? I beleive the bolt pattern is same....Thanks in advance.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
if the bolt pattern is the same and the offsets are crazy, then they should fit. but you need to know those two answers first.
Q45tech
Nissan and Toyota use different hub centric diameters ~~ Toyota is 6mm too small.
Rex
Car: None
Q45tech wrote:Nissan and Toyota use different hub centric diameters ~~ Toyota is 6mm too small.
Exactly, and you do not want to attempt to drill the Lexus hub/hole out to fit a Nissan/Infiniti.
Q45tech
Not to say that it might be possible by a mchine shop, the cost to be PRECISE and the weakening of the wheel might be serious.
