huguetguy wrote:Did most all S14's have ABS? If I get an ABS/5spd driveshaft from an S14, do you think it would work?
What about if I want to swap in a VLSD in the future? Anyone know what VLSD's will fit my S13 and should I get a different driveshaft that will fit both the new S14 transmission and the VLSD?
Dave
No, I don't think most came with ABS... obviously a lot of them did though.
Yes, the ABS driveshaft is shorter for the reason I mentioned in a previous post. As for an s14 ABS driveshaft fitting your s13, I don't know.
I believe the s13 and s14 diffs are direct swaps, so you should be all set... I am NOT sure of this, so don't take it as gospel. One thing to keep in mind, the wheel base length and width are different on the two cars, so this may affect driveshaft length and output shaft lengths.... but I am not as familiar with s13 specs, so you should research this for sure.
