stealth_240 wrote: and i will obviously be drifting it, so will there be any added stress to my motor to the point of sh*t braking left and right???
Most likely, yes. If you're going to drift it (because why else would you buy a 240, right?..), you're going to be running the engine at sustained high rpms, using stock parts- something the KA was not really designed to do. Eventually, you will probably break engine parts.
A 3 angle valve job probably won't do anything to promote longevity. If you're serious about rebuilding for a project like this, I'd say at least upgrade your valves springs with something that will be able to take the abuse.
