will ka24e oil pan work on s14 ka24de?
95hondakillr
Car: 240s
Does anyone know if the ka24e oil pan will fit and actually work right on an s14 ka24de? Also what is the best fitting to use to tap for turbo oil return line? Any info is appreciated.
alex240sx
Car: 91 240sx
no!! the ka24E wont fit a ka24de
3rD GeAr
Car: cars
i have a S13 ka24de oil pan on my ka24e(they are the same) but the S14 one may be different. Check with Nissan. good luck
1998cc
THe s14 oil pan is the same as a s13 ka24de. I have one sitting in my garage right now.
95hondakillr
Car: 240s
K thanks!
bbandit
1998cc wrote:THe s14 oil pan is the same as a s13 ka24de. I have one sitting in my garage right now.
its nice to know that.. cuz i have an 91 ka sitting in my friend's garage and i have a 95 ka sitting in my car... now i can go ahead and drill/tap an oil bung on that 91 oilpan so whenever all of my turbo parts are complete... i will just have to bolt it in
bruinbear714
The KA24E and KA24DE oil pans aren't interchangable, but the KA24DEs are, which means s13 and s14 dual cam engine's oil pan can be changed.
3rD GeAr
Car: cars
bruinbear714 wrote:The KA24E and KA24DE oil pans aren't interchangable, but the KA24DEs are, which means s13 and s14 dual cam engine's oil pan can be changed.
i believe they are since i have a "de" oil pan on my "e" and they were identical, the bottom end on both the "de" and the "e" are the same only differences are in the head. as far as i know they are the same. dont want to start an argument, just want to get things straightened out.
bruinbear714
3rD GeAr wrote:i believe they are since i have a "de" oil pan on my "e" and they were identical, the bottom end on both the "de" and the "e" are the same only differences are in the head. as far as i know they are the same. dont want to start an argument, just want to get things straightened out.
Where did you get this information? Last I heard and saw, the oil pans aren't interchangeable.
3rD GeAr
Car: cars
as far as i know my 90 ka24et has a 92 ka24de oil pan on it but maybe told me the wrong year. i would like to see pics of the two to see differences if so. i just want to know if it does.
