iknowyoulike »
https://forums.nicoclub.com/iknowyoulike-u15074.html
Sat Sep 03, 2005 5:32 am
also depends on the turbo if your running like a t25 ( what i have) you should be fine but an upgrade from that it might be a good idea to run both just cause it will see way more heat plus you'll kick your self in the *** if it craps out on you cause you decided not to hook up water lines...just my 2 cents..good luck!
