reiinitial »
https://forums.nicoclub.com/reiinitial-u70646.html
Wed Jul 11, 2007 11:14 pm
How long did you let it cure? JB Weld could be considered a temporary fix. for it to have a more solid hold, you'd need to remove the part you wish to use it on, and clamp the two parts together. it really needs at least 24 hours to cure properly. i've used JB Weld on many different kinds of metals, and there are a multitude of variances that could or could not allow it to bond. it'll hold tight, as a "glue", but for filling in holes it's not very good. on top of letting it cure longer, and clamping it, it'll be more likely to hold if you create scratches on the two objects, where you're going to "weld" them together, so it has a better grip on them. it's not so useful on polished, or just plain smooth, objects.
