Jeff Williams »
https://forums.nicoclub.com/jeff-williams-u431.html
Tue Feb 06, 2007 3:27 pm
Dan, try calling Slim (450zxtt). He put a complete Q45 rear end ,axles, and hubs in his 300zx, to get the higher rear end (he wants 200 MPH). It seems that the 300zx subframe is a little narrower than the Q45 subframe, but it fit. You might have trouble going the other way, but some simple spacers between the axle shafts and differential should do the trick.
I have not done it, or tried anything like it, but he has.
I just bought a JDM Skyline 4.11:1 rear end for Lola. Now, I need to get a std, non TCS housing to do a gear swap, since the JDM rear end has no ABS sensor on the input shaft, but two on the output shafts. I may just disable the ABS anyway. I feel more comfortable doing my own skid control anyway.
Good luck and let us know what you find and do.
