Will it PLUG.........
WONit
Car: 89' 240sx Redtop
im buying a s14 sr20det and i wanted to know if it was plug n play?i have a 92' 240sx!!!!
FAST-DATSUN
NO!!!!!!!!!!!!!!!!!!!!!
WONit
why not??????????
912.0turbo
Because its an S14 motor and you have an S13!!!!!!!!!!!!!!!!!
WONit
so if i go s13 it should bolt rite on up huh?!?!?!
912.0turbo
Just yankin your chain. I THINK the only difference is the wiring. But the S13 does bolt right up.
SpeedRacer1
Car: 1990 240SX, G35
The S14 engine harness will have more plugs than the S13 has to plug into. There are certain imcompatable items, for instance your temp gauge may not read properly because the S13 and S14 temp sensors give off different signals. Others like the speedsensor may need to be changed to an S13 sensor.
There are 3 generations of S14 SR20DET's. The only real differences between them is that the wiring is changed slightly. The early model uses an ECU that has a red WC symbol on it. Middle gen has a black WC symbol on it. The latest gen has a NA symbol on it.
The WC's shouldnt be terrible hard to install if you use the S14 SR20DET FSM available here: http://www.zeroyon.com/TheSite/techservice.html
The wiring for the last gen engine with the NA ecu isn't readily available. My friend has a late model S14 SR, we just used the entire harness off the clip rather than trying to figure out the wiring.
The wiring will be the only major issue, the engine should drop in just fine without clearance issues.
WONit
well i think i will have 2 go with the s13 becouse i dont like wiring as it is and im putting it in myself
so far this is what in getting
s13 engine, transmission, ecu,ignitor chip,wiring harness 2375greddy front mount intercooler kit 730greddy down pipe 180act stage 2 clutch kit 360seibon vs carbon fiber hood 475
is there anything else that you all think i need ,or do you know of any better prices than what i have here?????
912.0turbo
Fuel pump comes to mind.
WONit
what kind of fuel pump and prices
912.0turbo
Walbro 255lph, cost anywhere from 90-130 bucks.
SpeedRacer1
Or you can get a 300ZX pump. Quality oem but almost $300.
WONit
well r rite
WONit
no one told me that i would need a hot pipe,c'mon yall supose 2 be some pro's rite
912.0turbo
Search FOOLIO!!LOL!
GhostRider240sx
Car: 2008 G35x Sedan
Journey
StocK
I started my sr project and i thought iwas simple, if you buy or ahve bought your engine check it out completely. and have enough money for eveything. my mechnic tried to cut corners and damn its messed me up.
WONit
i plan on replacing all the gaskets, hoses and stuff like that 1st thing,and anything else i see wrong.but besides that it was a fairly easy project?
and searchin on this site is a bytch
912.0turbo
WONit wrote:and searchin on this site is a bytch
Yeah its changed.try searching in the archived files you might find what your lookin for.
WONit
what should i type in there?sr20 instalation brings up 1 hit
912.0turbo
Try spelling it with 2 L's.
WONit
Typed it w/2 LL's and still nothing..............NEXT
WONit
nothin else that i might need to intall engine?
Pepperoni
Just go to http://www.srswap.com and look at their install faq. should answer most of your generic questions
Def
Car: Cars, Engineering Stuffs
If you don't think you can do it after reading the SRswap faq - then I suggest paying someone to do it.
It really isn't that hard overall, just time consuming at parts if you're by yourself.
I thought the wiring was quite easy, and it was my first time doing any kind of wiring on a car. Just bought a cheap solder gun and went to town following the directions. My swap fired up right first time no problem.
Just follow the directions on SRSwap
WONit
GOTCHA ,THE ONLY THING I WAS WORRIED BOUT WAS MAKIN SURE EVERYTHING BOLTED UP AND I WANTED TO KNOW HOW HARD THE WIRIND WAS
TristanDET
for the wire harnesHEAVY THROTTLE
They did mine in 1 day and sent it right back to me.Very neat job too only $118 totalCant beat it (if you cant DIY)
WONit
the wiring harness with th s13 wont plug rite up?
WONit
any 1 any
