Will it fit
blackbeltclub99
Car: 93 RX7
I have a 95 240SX SE. SIZE AND SPECIFICATIONS: There are two different size wheels. For the front are the 17" x 8" (+20mm with 5.24" backspacing) and the rear are the 17" x 10.5"! The rear wheels are +27mm offset with 6.63-inch backspacing. They are 5-lug (5 on 4 ½). any help would be great.
Cloudedone
Car: Cars, Drifting, Auto Mechanics, Army, Chicks
In the Front you will have 1mm more clearence from the strut housing to the inside of the wheel, and they will stick out an extra 39mm.
In the back you will have 38mm less clearence from the strut housing to the inside of the wheel, and they will stick out an extra 64mm.
btw i checked that with this in the faq...http://toy4two.home.mindspring.com/offset.html
-Galen
blackbeltclub99
Car: 93 RX7
Will they clear Tein FLEX coilovers?
Cloudedone
do your SE 5 spokes clear? if so they will work in the front ok... If your SE 5 spokes clear in the back get out your measuring tape, go under your car and measure from the inside edge of the rim to the strut housing, if its more than 38mm, yes... not that hard to figure out how to check for urself tho...
-Galen
blackbeltclub99
Car: 93 RX7
thank you very much!
