Will it fit from MB?
Shocks, springs, sway bars, coliovers, bushings, brakes, wheels, tires - This is the place to discuss G-Series suspension modifications!
harp00n
Car: G35x '07
Will the rim from a MB ML350, 17", 7.5" will fit a G35x '08? I'm not sure about the offset and the bolt placement (though there are 5 bolts).
JeromeS13
Car: 2008 Subaru Impreza STI
A quick google search for "mercedes ml350 bolt pattern" yields your answer; no, they will not fit. Mercedes bolt pattern is 5x114.5.
-Jerome
C-Kwik
JeromeS13 wrote:A quick google search for "mercedes ml350 bolt pattern" yields your answer; no, they will not fit. Mercedes bolt pattern is 5x114.5.
-Jerome
Last I checked, the G35 along with most other non-european 5-lug patterns are 5 x 114.3 (4.5 inches). Perhaps you mixed them up as it seems the ML350 may be sporting a 5x112 pattern in my search.
awdjdmtalon
Car: 04 G35 Coupe, Diamond Grafite Metalic, Aero package, 6MT
98-04 VW Passat, Audi A4 and A6 are 114.3 X 5. Both had BBS wheels as options.
JeromeS13
Correct. I know the bolt pattern for the G35 is 5x114.3. I guess I just looked at the wrong numbers when I stated 5x114.5 for the MB.
Either way, they won't fit.
SleeperG37
Car: 2008 G35S
awdjdmtalon wrote:98-04 VW Passat, Audi A4 and A6 are 114.3 X 5. Both had BBS wheels as options.
Most Audis, including the A4, as well as MB are 5x112, not 114.3. BMW is 5x120.
zozoka1212
Car: 08 Infiniti G35x
Gash I always hated this bolt patterns. Why not just standardize the size and you can use everything.
zozo
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
MB is 5x112
Infiniti/Nissan is 5.114.3 or 5x4.5
now, you CAN get these to fit via a bolt pattern conversion kit
I wouldn't recommend it though
FBW
Def will not fit.
Return to “G35 and G37 Suspension, Brakes, Wheels and Tires”
