Will it Fit?! 34s on an R50.
alexf20c
Car: '00 SE 4x4
after some motivation with my dremel, prybar, and hammer, i think i've made enough room to fit 34s on my AC lift.
i've ordered a 285/75-16 Interco SSR which measures 33.9in. we shall see!
here's a shot with 33s, which have worn down to 32in actual, in this pic.
i dremel'd the rear bumper and can move the front bumper forward on its mounts by about 1in, if i need to. at the bottom of the front doors, i folded the fenders a bit more, and i don't think i'll have issues at the bottom of the rear doors.
Modified by alexf20c at 6:24 AM 1/19/2010
muddfildvaynes
Car: 1999.5 Nissan Pathfinder
Let me know how it goes, have you thught about putting in the SFD? I want to put 34's but was going to after I put in the SFD... could you take some pics of your fenders and how you "rolled" them?
alexf20c
Car: '00 SE 4x4
i'm not that interested in a SFD. definitely not for the price that most builders (or local shops) are asking for them. who is making your SFD?
this is the bottom of the front doors.
i'll get pics tomorrow of where/how i dremel'd the rear bumper.
Pwnin O'Brien
That's going to be super tight. What about the front wheels at full lock? Did you do any front wheel well trimming?
KyooX4
Car: 2001 Infiniti QX4 4wd
Will there be issues clearing the struts?
fueler
Car: 2 Nissan's
2 BMW's
lol i had to do the same thing on the front fenders, but not as extreme.
what sliders are those ?
GRNMACHINE
Car: 1999.5 Pathfinder SE 4x4
Based on the pics that looks like it is going to be a tight fit. Looking forward to pics and looks like you could still bend or cut a little more if needed.
alexf20c
Car: '00 SE 4x4
the sliders are the Super Sliders from Rocky Road.
the only trimming on the front wheel well was the rolled fender at the bottom of the front doors. i've been wheeling several times since fitting the 33s and there's absolutely no rubbing, even at full lock.
there shouldn't be any strut clearance issues. i have 1.5in wheel spacers.
alexf20c
Car: '00 SE 4x4
you can see here where i dremel'd away the leading edge of the rear bumper. i removed about 1in of material.
fueler
Car: 2 Nissan's
2 BMW's
what size are those tires? sure dont look like 33's dont even look like 32's to me.... maybe 31 and a halfs....
alexf20c
Car: '00 SE 4x4
if i'm running 31.5s, you're running 29s. :
alexf20c
Car: '00 SE 4x4
you still have your fender flares. they overlap the wheel well by nearly 2in in the back. if you really want to make room for big tires, you need to remove the flares.
Modified by alexf20c at 12:33 PM 1/19/2010
fueler
Car: 2 Nissan's
2 BMW's
alexf20c wrote:if i'm running 31.5s, you're running 29s. :
roll your eyes all ya want.
<<< these are 32's
alexf20c
Car: '00 SE 4x4
never said they weren't. now go get your tape and see if they're still 32s.
mine are bald 33s which now measure out to 32in. that, and i'm not running fender flares so it makes the tire look smaller due to the extra clearance.
read it and weep
fueler
Car: 2 Nissan's
2 BMW's
well ill be damned. it must be the 16's throwin me off, i had 17's. sorry for doubting you
alexf20c
Car: '00 SE 4x4
i still think i can fit 34in swampers, but i couldn't pass up this deal on toyota steelies and 285/75-16 (33.1in) BFG KM2s
i'll post up more pics once i get them mounted and installed.
Modified by alexf20c at 8:34 PM 1/24/2010
GRNMACHINE
alex,lookin forward to pics! Nice find. I like how the valve stems are protected inside the wheel instead of on the lip. Never heard anything bad about those BFG's aside from the price when purchasing new. Older Mud-Terrains were not very good on pavement, new KM2's are supposed to be decent. I would have purchsed them when I went up to 33's on my Explorer but they were way too pricey for me.
alexf20c
Car: '00 SE 4x4
nice catch on the valve stem! i noticed that also, and that alone makes this set of wheels worth the $50 i paid for them. the nissan steelies i use are basically a recessed flat face with the valve stem sticking out precariously, easily susceptible to trail damage.
i've never broken off a valve stem, but i've seen it and am glad that these toyota wheels address that issue - intentional or not.
alexf20c
Car: '00 SE 4x4
they cleaned up nicely
fueler
Car: 2 Nissan's
2 BMW's
looks good , post pics of them mounted on ride
GRNMACHINE
Yes, lets see some pics!! They did clean up nice.
screwinitupagain
Car: 1997 Nissan Pathfinder SE
It'll fit, but it all depends on how much cutting you want to do. I can fit 33x12.5 on a 15x10 rim with the AC lift & miner trim & I know I can fit 34's with the cutting I want to do
alexf20c
Car: '00 SE 4x4
i can fit 34s as it sits right now.
anyway, the minivan is getting SAS'd so it's a moot point. swapping out the rear axle as well.
SixGuns
Car: '04 Nissan Pathfinder SE 4x4
Since you mentioned it...how's the SAS going? I saw you had a 3 link stat on your sig but....wtf man, no pics of the progress? What's the deal?
01silvapathy
Car: 2001 Pathfinder LE 3.5
Nope, he is still IFS. Has the parts but he is pussing out and having a shop do all the work
alexf20c
Car: '00 SE 4x4
01silvapathy wrote:Nope, he is still IFS. Has the parts but he is pussing out and having a shop do all the work
speaking of pussing out, didn't you need to take your pathy to a shop because you couldn't loosen the lower strut bolts? and what happened the last two times we went to Barnwell, and you said you were gonna meet us up? oh ya, you pussed out.
yes, i am still IFS. i'm just waiting for a few more parts before i can finally get started. i have neither the skills nor the equipment to weld/fabricate all the custom parts needed to install new axles front/rear.
i've seen the caliber of the work your friend does in making front bumpers; i'm glad he is not my fabricator. i don't want my s*** getting ripped off in a small recovery.
