Darius »
https://forums.nicoclub.com/darius-u5470.html
Tue Mar 13, 2007 10:50 am
Starters are pretty basic. They only need a power source, the housing is grounded to itself on the starter so you CAN'T screw that up. The only thing is getting the signal wire to fire the solenoid and engage the flywheel. Look through the FSM for your 240 and find the starter wiring diagram and go from there. If you KNOW the wiring is correct, then take it to the shop and have them test it. Put a boot in their *** if they give you grief, it's just laziness.
