ILikeMy240sx »
https://forums.nicoclub.com/ilikemy240sx-u16757.html
Tue Dec 06, 2005 2:22 pm
Diam *width - offset = A
If A is zero then it will clear if A is not zero it will not clear.........
You cant just give wheel specs and tire specs(why do you need this to figure out if your caliper will clear?) and ask a question like will a caliper clear... A lot of it has to do with spoke design as well not just the offset. I say go with lower offset.. I have 17*8 and 20 and its flush with the fender. I believe my spoke design allows my Z32 calpers to clear with a lot of room. If I had 20 offset and ****ty spoke design, I would not be able to clear the calipers.
Oh and, with lower offset, you will have better luck clearing coilovers if you choose to do so later on.
