yea i know the break in procedure and thanks for reminding me about keeping my RPM moving.Ekinchheng wrote:You could drive it home but I would make sure everything is safe before you take it out of the road (No leaks,overheating,etc) If its a freshly build motor and you haven't driven it, I would warm up the engine and drive it around the block a couple times and change the oil. That way there won't be no metal shaving left over from the rebuild. Then you should be safe driving it home. Just try not to stay a a certain rpm and your good.
hahaha hummmmmm maybe i should lol!my mechanic has a different way of breaking the motor in and i go by the MOTO MAN way.Samurai C wrote:red line ever gear on the way home
your mechanic should be test driving it befor he hands it over. i test drive the motors i install for almost a day to make sure there are no problems. im sure you will be fine and like Ekinchheng said make sure you change your oil at like 500 to 1000 miles on the new motor
can i ask what cams you put in im looking to upgrade. i was looking at the BC stage 2 or JWT
One problem, car is running rich asss helll!. black smoke and kind of low idle, little lopie idle im guessin maybe it's the BC 264 cams. Enthalpy ecu, 740cc nismo injectors. stock t25 from sr(upgrading after break-in).sunnys14 wrote:I drove my car 15 mins after I started it up for the first time. Just let it idle for a little while to check for oil and coolant leaks. After that it took it on the road. Changed my oil about 100 miles later.
10,000 miles later it's still good as new
I used the 350z throw out bearing.Ekinchheng wrote:Hey sunny I've seen your thread when you talked about the rb flywheel and 350z clutch I was wondering what you use for the throw out bearing?
I have an innovate lc-1/xd16 wideband, BUT havent install. so i have to get it installed. and i changed oil and clean out spark plugs, the car was only turned on and not driven yet. I do have afcneo hooked up but i guess i'll wait for the wideband before i start messing with it.480sx wrote:WBO2 sensor confirmed?
Running a new motor rich is really, really bad. The rings arnt sealed and the excess fuel will pollute your oil in a quickness which will ruin your motor. I know from personal experience.. Dont drive the thing until you lean it out.
ok so i did the oil change and lean it.sunnys14 wrote:No need to run stock injectors or stock ECU while NA.
I ran NA with Sard 850cc's, z32 maf and enthalpy ECU for about a month with no problems.
thanks sunny, i'll try to fix it one more time and then go back to stock, how did you break-in at higher(around 4k) rpm w/ bigg injectors when turbo is out. wouldnt that flood the motor since theres no turbo and ecu set the injectors to flow higher during boost 2.5k+ rpm? also how did you work around w/ z32 maf on pipe?(forget it i have greddy FMIC pipe that i can use w/ that z32 maf to throttle body ). hummm...i would have to find a cap to seal off the egr hole thats in my stock exhaust manifold. all my egr crapp are off so i hope it doesnt give me any prob.sunnys14 wrote:1-12-23-34-45-5
It should all work out the same.
This is why I hate breaking in the motor while turbo, so many other things to worry about while breaking it in...
I beat the crap out of the motor while NA and no I did not flood the motor at high rpms.240sxvaj wrote:
