C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Sat Sep 28, 2002 3:30 pm
It all depends. Check the wording in your policy. There is no definite answer. Every policy will differ. Even from the same company, policies generally differ from one state to the next and from one company to the next. Some companies even have different policies in the same state. Most policies will state something to the effect that your vehicle and its equipment is covered. Most policies will put limitations on electronic equipment. Some limit the type of equipment, others will both the type and put a dollar limit on it. When it comes to aftermarket equipment, you may find an exclusion that does not cover non-OEM or non-OEM replacement parts. Generally the better companies do not have as many exclusions, but are usually more strict in their underwriting practices so that their exposure to this type of risk is minimal. Most carriers who exclude or put strict limitations usually will endorse aftermarket parts for an extra premium.
As far as the comment about if someone else is liable for your damages, do not rely on this when insuring your vehicle. When you purchase insurance, your best bet is to insure it in terms of what your actual loss could be. For one, you can not be sure that someone else will be liable. And even if they are, there's the chance that the person takes off, is uninsured, or even denies liability. Remember that it is a plaintiff's responsibility to "prove" liability and damages.
As far as value added, usually, aftermarket parts will add a small amount of value depending on the type of mod. But don't expect tp get what you put in. It's not dependent on what you put in, but what value it actually adds to the vehicle, or in other words, what would a reasonable person buy the car for...
