will Infiniti G35 stock wheels fit my 99 Q45t?
GM991
Car: 1999 Q45
I have a chance to get these for short money.Will they fit?Are they the same width?I think my stock Q45t's are 17x7.5
thanks
Rex
Car: None
GM991 wrote:I have a chance to get these for short money.Will they fit?Are they the same width?I think my stock Q45t's are 17x7.5
thanks
G35 Coupe or Sedan?17's or 18's?
Need more info.
The G35 OE tires are almost certain to be 91 load rating fronts, thus not near the Q's required minimum, but that's only and issue of the tires are included.
GM991
Car: 1999 Q45
Need more info.
Sorry sedan and they are 17'sI would be buying winter tires for them anyways....not that I have need them up here in boston this year yet...
thanks
Rex
Car: None
The sedan 17's will be a little narrow and "sunken", but for winter tires narrow is better and the comsetics is a non-issue.
GM991
Car: 1999 Q45
So are the
Rex wrote:The sedan 17's will be a little narrow and "sunken", but for winter tires narrow is better and the comsetics is a non-issue.
so is the 99Q45t's rims 17x7.5??What is the width of the G35's? 17 inch rims?
Falkdesigns
Car: 1998 Q45t ~ EXE
More important, or just as important as the width is the offset. Just because they may be the same width, if the offset is totally wrong, it won't work.
Rex
Car: None
GM991 wrote:So are the
IIRC, the Sedan is 17x7 all aorund and the Coupe is staggered 7.5 & 8 (with lower offsets)
GM991
Car: 1999 Q45
Ok so maybe the quistion iswhat nissan/infiniti 17" rims will work on my 99 T.And I mean bolt right up no prob.
Thanks
TgduMg
Car: 94 Q45, 02 Maxima SE
GM991 wrote:Ok so maybe the question iswhat nissan/infiniti 17" rims will work on my 99 T.And I mean bolt right up no prob.
Thanks
Since you would like to install these for winter tires I'm including a few 16 inch fitments that may work at the bottom of this post.
I know for a fact that all of the 17 inch fitments listed below (except for the 07 Altima SE and 07 G35 sedan 17x7.5+45mm wheels) will fit the (F)Y33 with no problems with the proper size tires.
The 07 Altima and G-Sedan 17 inch wheel fitment may work with no problems, I just don't know for sure if they will.
And yes, there is the question of the wheel load rating on some of these.
The near flush fitment of the 7.5 wide +30mm wheels is a real good look on the 97-01 Q45.
If you were to install some 97-01 16x7+40mm Q45 wheels to replace the 17x7.5+30mm wheels from a 99-01 Q45t
The clearance from strut housing to the inside of the wheel will be 4mm LESSThe outside edge of the wheel will RETRACT in towards the body by 16mm
marksink.com/wheeloffset or 1010tires.com/WheelOffsetCalculator
Here are some other fitment comparisons to the 99-01 Q45t wheels
17x7+45mmThe clearance from strut housing to the inside of the wheel will be 9mm LESSThe outside edge of the wheel will RETRACT in towards the body by 21mm
00-01 I30t 5-spoke02-03 I35 Sport 8-spoke03-04 G35 sedan 6-spoke05-06 G35 sedan 7-spoke00-01 Maxima SE 6-spoke02-03 Maxima SE 6-spoke02-04 Altima SE 6-spoke05-06 Altima SE 5-spoke
17x7+40mmThe clearance from strut housing to the inside of the wheel will be 4mm LESSThe outside edge of the wheel will RETRACT in towards the body by 16mm
02-04 I35 Luxury 6-spoke02-03 Maxima GLE 7-spoke04-06 Maxima SL 7-spoke07 Maxima SL 7-spoke
17x7.5+40mmThe clearance from strut housing to the inside of the wheel will be 10mm LESSThe outside edge of the wheel will RETRACT in towards the body by 10mm
02-04 Q45 6-spoke
17x7.5+35mmThe clearance from strut housing to the inside of the wheel will be 5mm LESSThe outside edge of the wheel will RETRACT in towards the body by 5mm
05 Q45 8-spoke
17x7.5+30mmThe clearance from strut housing to the inside of the wheel will be THE SAMEThe outside edge of the wheel will extend to THE SAME point as the stock wheel
99-01 Q45t 5-spoke (& Anniversary Edition)03-07 G35 coupe (front) 6-spoke03-06 350Z (front) 7-spoke
17x8+33mmThe clearance from strut housing to the inside of the wheel will be 9mm LESSThe outside edge of the wheel will EXTEND an extra 3mm
03-07 G35 coupe (rear) 6-spoke03-06 350Z (rear) 7-spoke
17x7.5+45mmThe clearance from strut housing to the inside of the wheel will be 15mm LESSThe outside edge of the wheel will RETRACT in towards the body by 15mm
07 Altima SE 5-spoke07 G35 sedan split 5-spoke
16x7+40mmThe clearance from strut housing to the inside of the wheel will be 4mm LESSThe outside edge of the wheel will RETRACT in towards the body by 16mm
97-98 Q45t 5-slot, 97-01 Q45 20-slot
16x7+45mmThe clearance from strut housing to the inside of the wheel will be 9mm LESSThe outside edge of the wheel will RETRACT in towards the body by 21mm
07 Altima 2.5 and 2.5 S steel, 07 Altima 3.5 SL 6-spoke
16x6.5+40mmThe clearance from strut housing to the inside of the wheel will be 3mm MOREThe outside edge of the wheel will RETRACT in towards the body by 23mm
00-01 I30 6-slot, 03 G35 sedan 5-spoke, 00-01 Maxima GXE 9-slot, 00-01 Maxima GLE and 02-03 Maxima GXE 5-spoke, 02-04 Altima 2.5 SL 6-spoke, 02-06 Altima 2.5 and 2.5 S steel, 05-06 Altima SL 2.5 and 3.5 6-spoke
16x6.5+45mmThe clearance from strut housing to the inside of the wheel will be 2mm LESSThe outside edge of the wheel will RETRACT in towards the body by 28mm
97-99 I30t 5-slot, 97-99 Maxima SE 5-spoke
Hope this helps.
Danisiti 1
Modified by TgduMg at 3:05 PM 1/26/2007
