BACARDI_DWB »
https://forums.nicoclub.com/bacardi-dwb-u44458.html
Wed Mar 17, 2010 1:05 am
Danski,
if you think that it is wrong then please explain to me the correct answer, its easy to say something, but i would like to see you back up your reason for it to be wrong.
A wastegate is there to bleed off exhaust gasses that the turbo can not take without surging, it will do so at a specified boost level, and then progress to open further to let more exhaust go thru as the boost gets higher to maintain a certain PSI. if you look at any turbo dyno or listen, you can feel the surge of power while the wastegate is closed and once it opens, you can hear a difference and feel a difference in power. I highly recommend you read Corky Bell's book Maximum Boost, if you are unfamiliar with how a turbo system works.
Please don't come in a forum, say something is wrong without giving your explanation of why you think it is wrong. I am happy to say that I am wrong if someone presents a better case, but by judging your post, I don't have much to learn from you so far.
I would also have to agree with Float, he has an excellent point that it may be timing...
