Will I be OK Running this tire size?
GrilledCheese33
Car: 2008 Nissan Xterra
1972 Yamaha R5
2017 Sea Doo Spark Trixx
Hey guys, i found a deal on tires to mount on my 17" Z wheels and i was wondering if it will be good:
Wheels are
7.5" front
and
8" rear wide
What i am asking is would it be okay to run a 235/45/17 on the fronts? I know the rear will be fine,since thats what it has factory, but i just want to make sure i'll be good for the fronts. thanks guys!
EazyBreazy
you should be okay with a 225, but i would run a 215 personally, but i like a more rounded, ie slight stretch to my tires. what tire are you gonna run
GrilledCheese33
1972 Yamaha R5
the ones i'm looking at are dunlop sp sport FM 901's, and btw, its a 235 tire
BlackFlag_s13
You should be fine, but it'll look like a lot of extra rubber and you might run in to suspension clearance problems. I'd opt for different sizes...
RB20DETodd
Car: 92 Nissan S13 coupe SE RB20DET
215/45/17---- Front 235/40/17----Rear
I have the same widths and thats what im running, sidewalls are flat.
EazyBreazy
^ thats about what i figured
240sxjeff
Car: nissan 240sx zenki version
If your dead stuck on getting 235's for the front I would go with a 40 series instead of the 45 series which would be a bit too tall.But I agree with RB20 a 215-45 up front and 235-40 in the rear would be optimal for those wheel widths
nismofly
Car: 89 Nissan 240SX Hatch
i run a 225 on my 7.5's, i wouldnt go wider
