batman0505 »
https://forums.nicoclub.com/batman0505-u138840.html
Fri Aug 21, 2009 11:52 am
Okay, I will go with what you have suggested. However, I am thinking of spacing the rears out a little more....what would the max spacer that I could use be before it would require fender rolling? 20mm, 25mm?
As well, i'll be running winter tires/rims...going with:245/45/18's all the way around
When I have these on, does it matter whether I leave the spacers on or off? I was thinking of just putting them on without the spacers, and then installing the spacers and 20's next spring.
Your response time is insane...completely made my day, thank you!
