Will GTiR Main Bolts fit on a SR20DET RWD (rear wheel drive)
JDS Performance
I have been searching and seen a few posts about it but seems to be FWD (front wheel drive) SRs they are speaking of and I know not all parts are interchangable so... any help here would be awsome!
I know the GTiR main bolts are just as strong if not stronger than ARP studs - plus there will be no need to modify the GTiR main bolts - where you need to modify the upper oil pan or (2) ARP studs so they dont hit the oil pan. Also another benefit is you will not need to line hone the mains using GTiR main bolts where the ARP studs require it. I know most will be line honing anyways if your rebuilding but for the guys that are keeping the motor in the car and are upgrading while they are installing new bearings etc.
homeslicej2
Car: 1990 Nissan 240SX S13 SR'd hatch
I do not know, but I'm sure the guys at Mazworx would.
JDS Performance
Yes they do work - I found out on Zilvia
