s13sr20chris wrote:i guess i should add that i think 8.5to1 is plenty low. i would never ever go lower than stock compression on a sr20det. i know the gtir has lower compression but i would not want that personally. i intend to have 9.0to1 when my motor is built. i also dont like thick head gaskets. personally i say get a good metal gasket as thin as you can get and set your comp the right way with pistons.
