WILL ECU NUMBER 23710-54C00 RUN A S13 SR20DET BLACTOP ENGINE???
wickedevo9
Car: 91 240sx
NEED TO KNOW IF THIS ECU WILL WORK WITH THE SR20DET BLACKTOP ENGINE, CAUSE IM NOT GETTING SPARK BUT TO CYLINDER NUMBER ONE, AND I WAS TOLD THAT THIS IS THE WRONG ECU FOR THE CAR,ANY INFO WOULD BE GREAT THANKS
SpeedRacer1
Car: 1990 240SX, G35
NO, that is an ECU for an AWD SR20DET off of an RNN14 Pulsar. Wrong injectors, MAFS, turbo, other sensors. Its not programmed to even run direct ignition, the RNN14 SR runs off of a distributor.
BoBa524
Car: 1995 Nissan 240SX SE
^^^Dang you good.
