suzonka »
https://forums.nicoclub.com/suzonka-u238539.html
Sun May 17, 2015 6:13 pm
I just replaced the ceramic pads on my 2003 pathfinder 4 wheel DR captive rotors, the rotors had some rough surface yet within specs of thickness however they stopped well and even until I replaced the pads, now the truck has steering wheel shudder , I did bid them in right , I cleaned the rotors real good after I notice about 2 black spots on the rotor after about driving 400 miles around at slow speeds say 50 mph , so I sanded then clean and resprayed with the brake cleaner and it did get a little better. , still the shudder which stops shuddering at a 6 mph . my question, if I disable my ABS will the pads Bid in better and faster? then I can reconnect the fuse for the ABS when all is well or is this just a useless thought.
Rogue One on Mon May 18, 2015 2:33 pm, edited 1 time in total.
Reason: Typo
