will changin the fuel filter help my gas milage? and how?
D_roc
Car: 2001 Maxima 20th aniv edition
will it? and how will filtering fuel help my gas milage?thanksD
stickshifta
Car: 1999 infiniti i30t manual
not really man... i changed the fuel filter, the fuel injection system was cleaned and i used iridium spark plugs...and i didnt get the 29 mpg highway stated on the car review. city is out of this world low. when i push it i get like 12! ah!
bpomps
D_roc wrote:will it? and how will filtering fuel help my gas milage?thanksD
i changed my filter, i have over 100k miles and i noticed a difference right away. the pedal was very responsive after. the filter was toast, black and oily. the pump housing had metal fragments in there also. if u got about an hour i think it would def help - esp if you have 100k miles or so.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
stickshifta wrote:not really man... i changed the fuel filter, the fuel injection system was cleaned and i used iridium spark plugs...and i didnt get the 29 mpg highway stated on the car review. city is out of this world low. when i push it i get like 12! ah!
Something else is SERIOUSLY wrong, then.
KineKilla
Car: 1997 Infiniti I30t
I am pulling around 24-30 mpg in my 97 I30t. I haven't tuned her up yet since I've had it but I'll keep track of the difference it makes when I tune it up.
BOBCAT
Car: 2000 Maxima, 94 SER
I need to replace mine very soon. I a big grap in the responce time from the gas pedal. I think it is the fuel filter. I have 150K miles and it has not be changed as of yet. Soo, yea.
bpomps
i bought two so i have an extra one if anyone wants it - $15 shipped. OEM nissan check the part #.
BOBCAT
bpomps wrote:i bought two so i have an extra one if anyone wants it - $15 shipped. OEM nissan check the part #.
Which year maxima is it for? I have a 2000.
bpomps
its for a 2000 ! my max is a 2000. i bought this one online then found a local dealer who had one the next day so i went and got it and changed it same day. took me almost two hours. getting the housing apart was very tricky.i didnt want to deal with any return b.s. so i just kept it
flyboy367
Car: 95 maxima se 5spd
yes, as your filter strains the fuel it picks up impurities. this clogs up the screen reducing fuel flow = poor performance. replace it and you will feel the diff. then clean the tb, open up the exhaust and walla. i did all that and i installed the new bosch +4 irriduim plugs. i gapped each lead a little higher so it has a step up effect. my car pulls hard from 0-131 (fastest so far)
BOBCAT
flyboy367 wrote:then clean the tb,
TB??
I will buy it from you, just give me the information so i can get you paid. [email protected]
BOBCAT
Ohh, i went to autozone yesturday and they told me that i will not only have to replace the fuel filter but i will also have to replace the fuel pump. Is this correct. I didnt think it was but i might as well ask.
flyboy367
start with this, replace the filter when you are below a 1/4 tank of fuel. closer to E the better. dump in a bottle of stp fuel injector cleaner. drive to the gas station and fill up. spend the next 20-50 miles beating the everloving pee out of the car. hopefully that will clean out the deposits on the valves and stableize the injectors. then clean the throttlebody
bpomps
BOBCAT wrote:Ohh, i went to autozone yesturday and they told me that i will not only have to replace the fuel filter but i will also have to replace the fuel pump. Is this correct. I didnt think it was but i might as well ask.
i didnt replace mine so unless your pump is broken then you shouldnt have to - unless you want to get a new one since you are already in the tank doing the job. your results may vary !
BOBCAT
well, replacing the screen sounds like a good idea but i dont think replacing the pump would. I think it is all the fuel filters fault. Email me the payment information.
bpomps
BOBCAT wrote:
TB??
this email you gave keeps bouncing back !
