Will Ca18de Parts Work On A Ca18det???
dj_lennon_franz
Car: 1992 240sx
just normal maintanence parts like water pumps, drive belts, andtiming belts????
no one has been able to give me a straight answer....
so yah lemme know yall
Syntax360
Car: 1986 Nissan 300ZX Turbo
i'm almost positive....hasn't this been covered many times? search?
("just ask for parts for the 88-90 pulsar NX with the 1.8L Ca18De" <-- regarding CA18DET replacement parts in some thread around here)
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
yes it all fits
dj_lennon_franz
Car: 1992 240sx
so that means i can use CA18de clutches as well???? (oh god PLEASE say yes)
:ylsuper
Movingviolation240
You need to use a KA24DE (91-94) clutch, but the CA18DE bearings, crank, rods, oil pump, water pump, headgasket, headbolts, ect all fit on the DET.
shawya
Car: 1989 240sx Fastback
So I know the clutch disc from a KA24DE works on the CA18DET, but what about the pressure plate, throwout bearing, etc.? Knowing this would make everything so much easier to find.
JDM_1990_S13
i think you need to use the entire KA24 clutch set up??
and i believe i heard that the throw out bearings are all the same.
so you need:
KA24DE clutch, pressure plate and cover, throw out bearing.
i would liek to know too as i am planning on upgrading the clutch sometime soon.
