will ca18 or ka-t pass smog?
24j0hn
Car: 91' 240sx with some babying to be given
cuz i had my mind set on an SR20... but im not willing to spend $200 to have someone pass smog for me... So my two other options are CA18DET or just getting a turbo mounted to my KA24DE...
Will a KA24DE-T pass California smog
Will a CA18DE- T pass smog in california
Razi
Car: Moo
They will not.
24j0hn
your KA doesnt pass? are you registered
Razi
Car: Moo
I got it tested when it was stock, and registered it.Now it has a turbo, and most definitely it won't pass, bunch of my emissions stuff were removed during the process of going KA-T.
UndftdSole
Car: 90' 240sx RB25DET, 07 Subaru WRX
i am hoping you know someone who can help you smog.
AZ89two4Tsx
Either can pass easily. Just make sure you have all the emissions components hooked up. They will definately not pass a visual inspection but plenty pass smog. Most people just delete the emissions components because it's easier to do without, and/or they have a way to get around smog. Plus, there's a few tricks people use like high octane gas, seafoam, etc...
And OP, an SR is in the same boat as a CA or KA. It sounds like you think everyone is willing to take a $200 bribe, lol. There's no $200 magic ticket to pass smog although I would assume most people wouldn't turn it down.
themadscientist
My CA won't pass inspection in Japan!
24j0hn
well, i register in march and im probably gunna go KA-T in August... do you have the guide to KA turbo installation?
AZ89two4Tsx
Like a complete install thing? If you're going to be that lost you should have somebody that knows what they're doing help you/do it for you. It's not worth risking a perfectly good motor.
themadscientist
24j0hn
no... not a whole kit... i was gunna go t28 of used GT-26 from a supra and get a godspeed FMIC w/ piping... i need help on oil lines and water lines
AZ89two4Tsx
http://kat.org would be a good start.
24j0hn
it doent show me how to hook up the lines... that really all i need to know... unless if there is something else i need to do once i go KA-T... i know i need fuel pump, injectors, im gunna get nistune, and eventually rebuid the internals
AZ89two4Tsx
A lot of people don't bother running water lines, just the oil lines. I myself am not ka-t (yet) so I can't tell you what to do from experience. The way most people run their oil lines though is to tap a line somewhere for a feed and then for the return, you'll need to dril/fab a bung in your oil pan.
24j0hn
well, we could do this together haha... check this outhttp://www.nissanclub.com/foru....html
it says to tap the oil line at the oil pressure sender and to put the return into the oil pan
themadscientist
hook up the water lines. The life of your turbo will benefit.
duffman1278
Car: 89 240sx Hatch, the wildcats!
It will not pass
themadscientist
nissanman04
Car: '90 240SX, '95 Subaru Legacy
24j0hn wrote:it doent show me how to hook up the lines... that really all i need to know...
zerothread?id=312476
AZ89two4Tsx
^ Outstandnig writeup.
