Q45tech wrote:In 1994 there was a change to CAS and harness that make it necessary to create a single plug [from CAS] to 2 plug [wiring harness] adapter when trying to interface larter engine [94-95] to 90-93 harnesses.
Forget the 1996 engine as too many differences with OBDII changes to even work in a 1995 much less a 93.
Finding the connectors and CAS dangle and creating the interface requires you cannabalize the CAS from old 90-93 engine then find a connector from 94-95 engine harness.
This is 90% correct, except that a 94 CAS is two plug just like the 90-93 CAS. However, only the Secondary circuit shares the same plug, the primary circuit is redesigned and is the same on all 94-96 plugs.
If you get a 90-93 motor, any type will work and drop right in. If your car has TCS and the donor motor doesn't, swap TB setups, the same applies if it's the other way around as well.
If you get a 94 motor, it will drop right in, use your 90-93 coil harnesses, ignitor chips, etc. The secondary circuit on the CAS will plug right in, the primary circuit will require you to cut/spice the newer connector onyou your old harness or make a jumper harness.
If you get a 95 motor, the above applies but there is no secondary circuit to plug in on the CAS at all, you won't get a CEL.
Avoid a 96 motor, you can make it work but it is significantly more work.
