CA19DET »
https://forums.nicoclub.com/ca19det-u7344.html
Fri Jan 23, 2004 6:55 am
i have also noticed that:
OS GIKEN EXEDYa nd others have kits for the RB20 & RB25 that are 225mm and 215mm disk diameter, now i dont know if that means that the flywheel in the kit is smaller in diameter, but someone with access to all these exotic clutches should try a couple of the RB clutches and see if any work, the splines are the sme for sure, just need to ensure that the flywheel mounting bolts are the same and the diameter clearing the bellhousing on the CA transmission.
